Hi All,
Hope can have someone shed a little light on a problem I'm trying to resolve for a work project. Have a UE4 project which have exported as an ORBX file and imported successfully into Octane Standalone. Have then exported a sequencer sequence as FBX, converted to Alembic Cache and imported into the standalone project. Using a script that was provided from the following page: viewtopic.php?f=73&t=57252 I downloaded the Alembic Cam with Pano camera script from here: viewtopic.php?f=98&t=48769&p=243113&hilit=.lua#p243113
Where I'm having the issue is I"m not able to connect the alembic camera to a node in the Pano script. It's possible adding the script incorrectly but have followed the instructions. The only thing I did notice when adding the script is unless you already have a camera connected to the render target the script won't work, it spits out an error. If anyone could shed some light on what I could be doing wrong or how to connect it up that would be great. Here is a screen shot of what I have got: https://i.imgur.com/GnSIzJ7.png So you can see there is the ABC file, but where on the Pano node should this connect up to?
Although yes I am a Programmer I don't know LUA scripting and I am still pretty new to Octane.
Shez
