Project teacher reported an error
Posted: Sat Dec 02, 2023 2:21 pm
Started logging on 02.12.23 21:56:12
OctaneRender Studio+ 2023.1 (13000009)
VRAM used/free/max:0Kb/11.994Gb/11.994Gb Out-of-core used:0Kb RAM used:16.699Gb total:63.933Gb OpenGL free/total:0/0
FRAME:90 fps:30
Export materials time= 2555.389 ms
Collect objects time= 0.104 ms
Mesh creation time = 378.631 ms.
MB:0/0 ST/MOV:0/8 Nodes:44 Tris:1.334m DispTris:20k Hairs:0 Meshes:14
Textures Grey8/16:2/0 Rgb32/64:7/3
VRAM used/free/max:2.955Gb/5.059Gb/11.994Gb Out-of-core used:0Kb RAM used:21.983Gb total:63.933Gb OpenGL free/total:0/0
CUDA error (700) on device 0: an illegal memory access was encountered
-> failed to download symbol(stats data)
device 0: info channel kernel failed
-> failed to launch kernel(kernel54)
device 0: failed to update AI light
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered
denoiserThread0 : Exited with a error. Restart required
-> failed to destroy CUDA event
-> failed to deallocate pinned memory
-> could not get memory info
-> failed to deallocate device memory
-> failed to deallocate device array
-> failed to destroy texture objects
-> failed to unload module
OptiX error for device 0: [PIPELINE] Error synching on OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
Error destroying OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
OptiX API error for device 0: CUDA error
could not request a tonemap because we don't have any renderthreads available.
Failed to tonemap the render passes!
pass [Object ID] ID:1009 not found...
Displaying passes in tm=0.338
**** RENDER FINISHED **** stat=3
FRAME:90 fps:30
