ORBX - DAZ3D to Unity import issue
Forums: ORBX - DAZ3D to Unity import issue
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby OnlyVR » Thu Feb 06, 2020 1:31 am
OnlyVR Thu Feb 06, 2020 1:31 am
Did somebody tried to export a scene from Daz3D in ORBX format and import to Unity? The reason I try to do it Daz plugin cannot render stereo 360 for now. Unity plugin does it perfect.
So, when I try to load ORBX in Unity I get the error "Invalid AABB a".
Any idea?
OnlyVR
Re: ORBX - DAZ3D to Unity import issue
Postby ChrisHekman » Wed Mar 04, 2020 9:22 am
ChrisHekman Wed Mar 04, 2020 9:22 am
Could you share your ORBX with me? Then i can test what is going wrong.
ChrisHekman
Postby OnlyVR » Sat Mar 14, 2020 6:50 pm
OnlyVR Sat Mar 14, 2020 6:50 pm
Actually any ORBX created in Daz3D has this issue.
I've uploaded a simple test scene https://drive.google.com/file/d/1ao8huM ... sp=sharing The scene contains just two primitive plane objects.
In Unity:
1. Octane -> Settings -> Load Octane
2. Octane -> Load ORBX, select TwoPlanes.orbx
3. Octane -> Create PBR Render Target
4. Select PBR Render Target and click on Render in the inspector.
The scene is empty, "Invalid AABB a" error messages are coming.
If I use Octane -> Import ORBX then the scene shows up but there are different issues.
1) Materials are not loaded/created. Textures and meshes are fine.
2) Locations of object are not correct.
3) There is the error message in Console - "matIx 0 is out of bounds (0)"
Very likely this is the Daz3D plugin issue. In Daz3D try to export a scene to ORBX and load the same scene back. I always get the error message "Unable to import multiple materials, import aborted"
Daz3D 4.12.1, Octane Render 2020.1.0.52
Unity 2019.3.5f1, Octane Render 2019.1.1 Ver 1.2.0.1377
OnlyVR
Return to Octane for Unity
Tue Jul 07, 2020 4:58 pm [ UTC ]
