Baking Lightmap without the texture in Octane
Forums: Baking Lightmap without the texture in Octane
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby tronghieu » Fri Sep 06, 2019 9:06 am
tronghieu Fri Sep 06, 2019 9:06 am
I followed the video tutorial on your channel to bake the lightmap sucessfully. But i dont like when the texture is rendered into the light map. Is there any way i could exclude them or Do I have to render seperate passes and composite them back together ?
If so, which passes should I be using to have a good lightmap texture ?
tronghieu
Re: Baking Lightmap without the texture in Octane
Postby ChrisHekman » Fri Sep 06, 2019 10:39 am
ChrisHekman Fri Sep 06, 2019 10:39 am
Yes, octane support a colored "Irradiance Mode" and has an Irradiance Pass. These should give you the light map without the texture.
Either open up render passes and activate Irradiance.
Or if you want to denoise the lightmap:
- Turn on denoising
- Go to the kernel and select "Irradiance Mode". This will turn the beauty pass and the beauty denoised passes into irradiance passes.
*You might need to de-activate Irradiance in the render passes for denoising to work
ChrisHekman
Return to Octane for Unity
Mon Jan 20, 2020 6:34 am [ UTC ]
