1.2.0.1375
Forums: 1.2.0.1375
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
1.2.0.1375
Postby ChrisHekman » Thu Aug 01, 2019 2:55 pm
ChrisHekman Thu Aug 01, 2019 2:55 pm
1.2.0.1375
Features
  • RecorderWindow is now public
  • RecorderWindow StartRecording now also support directly rendering to disk.
1.2.0.1374
Features
  • PBRUnityLightComponent, Octane.UnityLight, are now accessable from the c# API
  • User can now select the brdfs on converted unity materials from the preferences window.
  • You can now request the converted material from the C# API.
    OctaneUnity.Scene.Instance.GetConvertedMaterial(unityMaterial)
  • It is now possible to start recorder via C#. (only record to ORBX rendermode for now, will add direct rendering later)
    RecorderWindow.StartRecorder()
  • Optimized various parts of the plugin. Experience should be a lot smoother.
ChrisHekman
Re: 1.2.0.1373
Postby mathaig » Fri Aug 02, 2019 4:51 am
mathaig Fri Aug 02, 2019 4:51 am
Whoa!!! excellent when, how ? with the official release of 2019 for unity or as an incremental build ?
mathaig
Re: 1.2.0.1373
Postby ChrisHekman » Fri Aug 02, 2019 8:38 am
ChrisHekman Fri Aug 02, 2019 8:38 am
You should be able to upgrade from within the plugin. Normally you should get an upgrade popup when a new version comes out.
Alternatively you can manually upgrade by going to the top menu bar -> Octane -> Preferences -> Version Control -> Select 1374 and upgrade.
ChrisHekman
Re: 1.2.0.1374
Postby mathaig » Fri Aug 02, 2019 10:06 am
mathaig Fri Aug 02, 2019 10:06 am
Maybe i'm doing something wrong here
RecorderWindow still not accessible when i do this:
OctaneUnity.RecorderWindow window = (OctaneUnity.RecorderWindow)EditorWindow.GetWindow(typeof(OctaneUnity.RecorderWindow));
Assets\Editor\rmBuildRender.cs(77,135): error CS0122: 'RecorderWindow' is inaccessible due to its protection level
As for the the PBRUnityLightComponent:
mathaig
Re: 1.2.0.1374
Postby ChrisHekman » Fri Aug 02, 2019 10:29 am
ChrisHekman Fri Aug 02, 2019 10:29 am
RecorderWindow
Ill check what went wrong here. Ill see if i can add a new build today.
Light component not found:
The PBR Unity Light Component only works when octane is rendering.
The underlying Octane.UnityLight only exists when rendering is active.
ChrisHekman
Re: 1.2.0.1374
Postby mathaig » Fri Aug 02, 2019 10:58 am
mathaig Fri Aug 02, 2019 10:58 am
Thanks. Could you please point me to the documentation for the PBRUnityLightComponenet please ?
mathaig
Re: 1.2.0.1374
Postby jdinh » Wed Aug 21, 2019 4:45 pm
jdinh Wed Aug 21, 2019 4:45 pm
mathaig wrote:Thanks. Could you please point me to the documentation for the PBRUnityLightComponenet please ?
+1. Is the C# API documented anywhere? I would love to dig into it.
jdinh
Re: 1.2.0.1375
Postby mathaig » Fri Sep 06, 2019 7:04 am
mathaig Fri Sep 06, 2019 7:04 am
I would lilke to request an API feature that builds on top of the ability to export ORBX. This would be a creucial step in automating our pipeline.
I will be really greate if i could execute the recorder in unity batch mode. This means, the ability to initialize Octane plugin in batch and performing the export.
Is this complicated to implement ?
regards
mathaig
Re: 1.2.0.1375
Postby ChrisHekman » Fri Sep 06, 2019 11:44 am
ChrisHekman Fri Sep 06, 2019 11:44 am
mathaig wrote:I would lilke to request an API feature that builds on top of the ability to export ORBX. This would be a creucial step in automating our pipeline.
regards
At the moment Octane can only be activated internally. Ill check if it is safe for us to expose it.
ChrisHekman
Return to Octane for Unity
Users browsing this forum: No registered users and 17 guests
Tue Apr 23, 2024 9:35 am [ UTC ]
