PBR Unity Light Component
Forums: PBR Unity Light Component
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby mathaig » Thu Jul 11, 2019 9:00 am
mathaig Thu Jul 11, 2019 9:00 am
It seems that the spot light range does not behave the same way as in Unity. I have read from another thread "Unity lights" that i can use the PBR Unity Light Component to tweak the lights.
mathaig
Re: PBR Unity Light Component
Postby ChrisHekman » Thu Jul 11, 2019 11:59 am
ChrisHekman Thu Jul 11, 2019 11:59 am
Yes unity lights do not follow the inverse square law, which means that octane cannot 100% replicate them.
You an use PBR Light Components by simply adding the component to the parent game object of an existing light component. It should automatically override the light settings.
ChrisHekman
Postby mathaig » Thu Jul 11, 2019 12:20 pm
mathaig Thu Jul 11, 2019 12:20 pm
It seems that PBR Unity Light Component is not exposed. I tried via the inspector and also via script. Using Octane 2018.1.3
mathaig
Postby mathaig » Thu Jul 11, 2019 8:24 pm
mathaig Thu Jul 11, 2019 8:24 pm
Yes but PBR Unity Light Component is not expose via the editor no via script. Is there some other script that i shoulkd get ?
mathaig
Postby ChrisHekman » Fri Jul 12, 2019 9:01 am
ChrisHekman Fri Jul 12, 2019 9:01 am
Yes, it seems PBRUnityLightComponents were marked as internal. This has been changed to public and should be accessable in the next build.
ChrisHekman
Postby mathaig » Mon Jul 15, 2019 11:01 am
mathaig Mon Jul 15, 2019 11:01 am
Oh good, and when is the next release happening ? Would it be the version 4 of the plugin ?
mathaig
Postby mathaig » Tue Aug 13, 2019 9:23 am
mathaig Tue Aug 13, 2019 9:23 am
So if i were to add the light component, what would happen:
1. unity light follows the inverse square law ?
OR
2. the octane representation of the unity light will be linear ?
regards
mathaig
Postby ChrisHekman » Wed Aug 14, 2019 9:46 am
ChrisHekman Wed Aug 14, 2019 9:46 am
Neither. The light component allows you you to edit and save the octane side of the light. For instance it allows you to turn a spotlight into an IES lights.
Octane is an unbiased renderer, which means that the inverse square law is an emergent property and not directly coded in.
This is an difference between octane and unity that is hard to bridge, as unity does code their light drop-off into the engine.
For the automatic conversion of lights we match the light intensity at 75% of the unity light range.
This means that everyting closer than 75% of the unity light range will be brighter in octane, and everything farther than 75% will be darker in octane.
ChrisHekman
Return to Octane for Unity
Sat Dec 07, 2019 11:25 am [ UTC ]
