Ability to export ORBX at runtime from script
Forums: Ability to export ORBX at runtime from script
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby oktomus » Fri Mar 22, 2019 2:58 pm
oktomus Fri Mar 22, 2019 2:58 pm
Hello !
I would like to export a ORBX file at runtime and from script. I suppose it's not possible right now because there isn't any public API but is it on your roadmap ? Or Octane on Unity is only for artists ?
oktomus
Re: Ability to export ORBX at runtime from script
Postby ChrisHekman » Mon Mar 25, 2019 9:30 am
ChrisHekman Mon Mar 25, 2019 9:30 am
I just checked and this is not currently possible to export to orbx via script.
Ill check if I can enable it.
ChrisHekman
Postby ChrisHekman » Tue Mar 26, 2019 2:32 pm
ChrisHekman Tue Mar 26, 2019 2:32 pm
Actually, there is a way to do this atm.
Octane.Scene.Save() will save the scene to Orbx for you.
ChrisHekman
Postby oktomus » Tue Apr 02, 2019 6:40 am
oktomus Tue Apr 02, 2019 6:40 am
ChrisHekman wrote:Actually, there is a way to do this atm.
Thanks! But i'm not sure it will work in runtime in a build.
oktomus
Postby ChrisHekman » Tue Apr 09, 2019 11:40 am
ChrisHekman Tue Apr 09, 2019 11:40 am
OctaneUnity in a Standalone Build is not currently supported no.
This would only work in editor, and in editor play mode.
ChrisHekman
Postby oktomus » Wed Apr 10, 2019 7:00 am
oktomus Wed Apr 10, 2019 7:00 am
ChrisHekman wrote:OctaneUnity in a Standalone Build is not currently supported no.
Ok thanks. ORBX is just a file so it could be technically possible to export it at runtime no ? If so, is it planned or in the back of your roadmap ?
oktomus
Postby ChrisHekman » Thu Apr 11, 2019 10:24 am
ChrisHekman Thu Apr 11, 2019 10:24 am
The Octane for Unity itself does not work without the editor in standalone for multiple technical reasons. Which means exporting dosnt work without the editor in standalone.
We are looking into a solution, but it is a hard technical problem to solve, so it will take a while.
ChrisHekman
Postby oktomus » Thu Apr 11, 2019 12:06 pm
oktomus Thu Apr 11, 2019 12:06 pm
ChrisHekman wrote:The Octane for Unity itself does not work without the editor in standalone for multiple technical reasons. Which means exporting dosnt work without the editor in standalone.
Ok thanks a lot !
oktomus
Return to Octane for Unity
Fri Feb 28, 2020 9:34 pm [ UTC ]
