1.2.0.1370
Forums: 1.2.0.1370
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
1.2.0.1370
Postby ChrisHekman » Thu Mar 14, 2019 1:07 pm
ChrisHekman Thu Mar 14, 2019 1:07 pm
Features
  • Upgraded to Octane 2018.1
  • C# API - User can now access various parts of the plugin via C# (Experimental)
Fixes
  • Fixed one cause for the "Did not receive available versions from server" error
  • Fixed plugin downloading issue when using Unity 2018 / .Net 4.0
  • Fixed issue with Override Materials losing connection to texture when texture is moved from one asset folder to another
  • ORBX unpacking now correctly copies texture settings
  • Removed "Updating Rendertarget" debug message
  • Added unity meta files for runtime.dll and Baking Shader
ChrisHekman
Re: 1.2.0.1370
Postby liujialin_art » Mon Mar 18, 2019 7:04 am
liujialin_art Mon Mar 18, 2019 7:04 am
License login expired, Unity program crashed
liujialin_art
Re: 1.2.0.1370
Postby ChrisHekman » Mon Mar 18, 2019 3:01 pm
ChrisHekman Mon Mar 18, 2019 3:01 pm
liujialin_art wrote:License login expired, Unity program crashed
Im sorry to hear that. Could you give me the License Login Expired error message? And if possible, your unity account details?
ChrisHekman
Re: 1.2.0.1370
Postby Sergey91 » Mon Mar 18, 2019 4:25 pm
Sergey91 Mon Mar 18, 2019 4:25 pm
Hey guys! Had the same issue with licensing. How this can be fixed?
Sergey91
Re: 1.2.0.1370
Postby ChrisHekman » Fri Mar 22, 2019 10:58 am
ChrisHekman Fri Mar 22, 2019 10:58 am
Sergey91 wrote:Hey guys! Had the same issue with licensing. How this can be fixed?
Hi Sergey,
This license issue should be fixed. Can you confirm?
ChrisHekman
Re: 1.2.0.1370
Postby oktomus » Fri Mar 22, 2019 3:01 pm
oktomus Fri Mar 22, 2019 3:01 pm
ChrisHekman wrote:Features
[*]C# API - User can now access various parts of the plugin via C# (Experimental)[/list]
I want to try this! Where can I find informations about it ?
oktomus
Re: 1.2.0.1370
Postby ChrisHekman » Mon Mar 25, 2019 9:29 am
ChrisHekman Mon Mar 25, 2019 9:29 am
There is no documentation atm.
The basic setup is that you can now access Octane components and set their settings via C#.
PBRInstanceProperties, PBRTerrainComponent, PBRRenderTargetComponent are exposed.
PBRRenderTargetComponent can return its Rendertarget member variable which contains the settings for it.
RenderTarget is derived from the Node class, which is how you can set various settings.
If you want to see what can be set and get from the rendertarget node, you can open the OctaneGUI and rightclick on a rendertarget node and press "Show in lua api browser"
ChrisHekman
Re: 1.2.0.1370
Postby Sergey91 » Mon Mar 25, 2019 1:36 pm
Sergey91 Mon Mar 25, 2019 1:36 pm
Hi Chris! Everything works well now. Thanks for fixing!
Sergey91
Re: 1.2.0.1370
Postby ChrisHekman » Wed Mar 27, 2019 11:21 am
ChrisHekman Wed Mar 27, 2019 11:21 am
Sergey91 wrote:Hi Chris! Everything works well now. Thanks for fixing!
Great to hear!
ChrisHekman
Re: 1.2.0.1370
Postby oktomus » Tue Apr 02, 2019 6:41 am
oktomus Tue Apr 02, 2019 6:41 am
ChrisHekman wrote:
oktomus wrote:
ChrisHekman wrote:If you want to see what can be set and get from the rendertarget node, you can open the OctaneGUI and rightclick on a rendertarget node and press "Show in lua api browser"
Nice :D Thanks !
oktomus
Next
Return to Octane for Unity
Tue May 21, 2019 5:16 am [ UTC ]
