Octane not working with Unity UI?
Forums: Octane not working with Unity UI?
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby lineofsight » Wed Oct 24, 2018 3:23 pm
lineofsight Wed Oct 24, 2018 3:23 pm
why doesn't Octane render the native Unity UI? I'm working with Unity 2017.3.1p1 and Octane 1.1.1.1324. Am I missing something?
Thanks a lot!
lineofsight
Re: Octane not working with Unity UI?
Postby FredMaher » Thu Oct 25, 2018 6:17 am
FredMaher Thu Oct 25, 2018 6:17 am
(Total newbie here)
I can confirm. (do I need to specify a license type for free single GPU use?)
I just tried with Unity 2018.2.8f1 AND 2018.3.0b7 with
Octane 1.1.1.1341
I get 2 Unity console errors:
Failed to locate cudnn64_7.dll
UnityEngine.Debug:LogError(Object)
Octane.DynamicLibrary:CheckPath()
Octane.DynamicLibrary:Load()
Octane.PluginDllLoader:LoadLibraries()
OctaneUnity.PluginController:Init()
OctaneUnity.PreferenceWindow:OnGUI()
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
AND
IOException: Sharing violation on path C:\Users\FREDSTOY\AppData\Local\Octane\Unity\2018.3.0b7_1.1.1.1341_T1\libfbxsdk.dll
System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
(wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int)
System.IO.File.Create (System.String path, System.Int32 bufferSize) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
System.IO.File.Create (System.String path) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
System.IO.File.WriteAllBytes (System.String path, System.Byte[] bytes) (at <ac823e2bb42b41bda67924a45a0173c3>:0)
OTOY.OctaneUnityPackage.Unpack (System.String inputFile, System.String outputDirectory) (at <3e79a0320ecc4479a2ea70ba217b866c>:0)
OctaneUnity.Upgrader.DownloadCompleted (System.String file, System.Boolean success) (at <3e79a0320ecc4479a2ea70ba217b866c>:0)
OctaneUnity.ServerClient.DownloadUpdate () (at <3e79a0320ecc4479a2ea70ba217b866c>:0)
OctaneUnity.ServerClient.Update () (at <3e79a0320ecc4479a2ea70ba217b866c>:0)
UnityEditor.EditorApplication.Internal_CallUpdateFunctions () (at C:/buildslave/unity/build/Editor/Mono/EditorApplication.cs:200)
FredMaher
Postby lineofsight » Fri Oct 26, 2018 7:18 am
lineofsight Fri Oct 26, 2018 7:18 am
Fred, please open a new thread. Your Problem has nothing to do with mine. I'm talking about Octane not rendering the Unity UI (i.e. Canvases, Buttons, Sliders, Panels etc.)
That being said, your sharing violation error most likely results from you having two Unity instances (or another second process) open and both are trying to access the same file.
IIRC, restarting Unity after the sharing violation has been taken care of should also fix the missing DLL error.
lineofsight
Postby Xhed » Mon Oct 29, 2018 9:40 am
Xhed Mon Oct 29, 2018 9:40 am
lineofsight wrote:Hi,
Thanks a lot!
The native Unity's UI is quite slow when drawing it from script (which we do for things like the Render Target controls), and converting the entire Octane UI (especially with all the messaging back and forth between Octane and Unity) would be too much of a performance impact.
- Rick
Xhed
Postby Xhed » Mon Oct 29, 2018 9:45 am
Xhed Mon Oct 29, 2018 9:45 am
FredMaher wrote:(Total newbie here)
Octane 1.1.1.1341
AND
Could you check this thread? I respond to a similar issue there.
- Rick
Xhed
Return to Octane for Unity
Who is online
Users browsing this forum: No registered users and 2 guests
Fri Apr 19, 2019 4:18 pm [ UTC ]
