Hey everyone,
it seems, no matter what I do I can not get octane to render motion blur from unity (or motion vectors for that matter).
Is there any specific procedure I should follow?
thx for your help
Moderator: ChrisHekman
According to the manual, the "Time" and "Shutter Time" settings do the same thing
tombube wrote:After experimenting with the post process techniques that use motion vectors I came to a possibly better solution using frame accumulation with a low Max. samples count. This should be a much easier solution for people who want to use the PBR Recorder to generate their data, but the recorder itself for some strange reason doesn't allow framerates higher than 120 fps...
I'd need a frame rate of around 1500 fps to have enough frames for a quality motion blur - one frame would be created from 50 frames with a Max. samples count of 10, so that the total number of samples for that frame would be 500.
Does anyone know if it is possible to get the PBR Recorder interface to accept that high framerate? Or is there a way of running the raytrace through a script instead of through the recorder? That probably would be the best option, since it would be possible to accumulate the 50 images on the fly so that they don't take up space on the drive.
Users browsing this forum: No registered users and 15 guests
