Timeline with Alembic track does not work
Forums: Timeline with Alembic track does not work
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby Sov » Thu Jun 14, 2018 4:42 pm
Sov Thu Jun 14, 2018 4:42 pm
Hi all,
I am experimenting with Octane on unity. I use a timeline with some alembic tracks but the octane recorder does not update the alembic object.
I use the official AlembicForUnity plugin (https://github.com/unity3d-jp/AlembicForUnity)
Other objects are rendered with the correct animation, but alembic objects stay frozen at the first frame
Even with the realtime render preview window open I can scrub along the timeline and see all animated objects move except the alembic ones (they do update if I disable and re-enable them).
It seems like the octane plugin does not sense the alembic mesh needs to be resent to the octane render process, is there a way I can force the mesh to be resent? Perhaps it could be added to the ProcessFrame method in AlembicForUnity/AlembicImporter/Assets/UTJ/Alembic/Scripts/Timeline/AlembicShotPlayable.cs
Sov
Re: Timeline with Alembic track does not work
Postby mistertim » Tue Jun 19, 2018 7:04 am
mistertim Tue Jun 19, 2018 7:04 am
I'm also having this problem, anyone able to help?
Thanks!!
mistertim
Postby Xhed » Thu Jun 21, 2018 4:25 pm
Xhed Thu Jun 21, 2018 4:25 pm
We're working closely with Unity on this issue. There is no signal from Unity when a mesh data has changed, and without this, we would have to resubmit all data to Octane just in case something has changed. It would grind the applications to a halt, and you could never render more than a single sample (as Octane would reset every time data got resubmitted).
Due to these problems, we currently don't support these kind of animations.
- Rick
Xhed
Postby mistertim » Fri Jun 22, 2018 6:19 am
mistertim Fri Jun 22, 2018 6:19 am
Roger that. Thanks for the reply!
mistertim
Postby zdy7532483 » Wed Dec 09, 2020 12:55 pm
zdy7532483 Wed Dec 09, 2020 12:55 pm
Did this problems solved ?thanks! :lol: :mrgreen:
zdy7532483
Postby zdy7532483 » Wed Dec 09, 2020 1:00 pm
zdy7532483 Wed Dec 09, 2020 1:00 pm
Xhed wrote:We're working closely with Unity on this issue. There is no signal from Unity when a mesh data has changed, and without this, we would have to resubmit all data to Octane just in case something has changed. It would grind the applications to a halt, and you could never render more than a single sample (as Octane would reset every time data got resubmitted).
Did this problem solved now?thanks :mrgreen: :geek: :ugeek:
zdy7532483
Postby ChrisHekman » Tue Dec 15, 2020 4:40 pm
ChrisHekman Tue Dec 15, 2020 4:40 pm
No, it has not been solved.
ChrisHekman
Return to Octane for Unity
Users browsing this forum: No registered users and 8 guests
Tue Apr 16, 2024 6:18 am [ UTC ]
