Octane Over-ride Not working
Forums: Octane Over-ride Not working
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby Iceman9 » Fri Feb 23, 2018 6:42 am
Iceman9 Fri Feb 23, 2018 6:42 am
I was watching Eric's 'Using Mini MetaVerse Scene Tutorial...regarding creating an Octane Material Over-ride.
After selecting the object and over-riding the material with Octane 'PBR Override' material this is what he sees on his screen.
When I try to follow along this is what I see after creating the override:
I get no 'View Source' button to access the Octane material graph, nor to add a texture. Also the object turns pink.
Advice?
Thanks in advance.
Iceman9
Re: Octane Over-ride Not working
Postby Xhed » Fri Feb 23, 2018 12:18 pm
Xhed Fri Feb 23, 2018 12:18 pm
Did you load Octane? It needs to be loaded for it to be active, so that you can modify PBR Override materials.
- Rick
Xhed
Postby Iceman9 » Fri Feb 23, 2018 8:32 pm
Iceman9 Fri Feb 23, 2018 8:32 pm
Yes. Octane was loaded. I was rendering with it.
Iceman9
Postby ChrisHekman » Mon Feb 26, 2018 3:25 pm
ChrisHekman Mon Feb 26, 2018 3:25 pm
Iceman9 wrote:Yes. Octane was loaded. I was rendering with it.
It seems that the override material EditorGUI is not being loaded and is falling back to the default material editor.
What version of Unity and what version of OctaneUnity are you using?
Also, are you getting an error or warning?
ChrisHekman
Postby Iceman9 » Fri Mar 02, 2018 7:00 pm
Iceman9 Fri Mar 02, 2018 7:00 pm
Chris, I didn't get an error as I recall.
I've tried one time since, different scene and conditions and as I recall it worked OK. I'll post again if it recurs.
Iceman9
Return to Octane for Unity
Tue Feb 18, 2020 3:35 pm [ UTC ]
