GPU Failures
Forums: GPU Failures
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Re: GPU Failures
Postby ChrisHekman » Mon Jan 14, 2019 2:58 pm
ChrisHekman Mon Jan 14, 2019 2:58 pm
Lewis wrote:
ChrisHekman wrote:
Lewis wrote:Hi guys,
This is for v4 in general? Also for standalone?
Could you export the unity scene as an orbx and load it in standalone and see if the error persists?
Hi Chris
Sorry i should explain it better, this is not really Unity only related, happens to me in LW plugin and in standalone. I think it's something in general octane core (i can't make 100% reproducible scene, sometime happens 5 times a day sometime works 5 days no problem) what triers that error (as you can see on forums there is several of users from various apps/dcc plugins have that error so it's not really strictly to unity only.
Sorry one more time for confusion thinking it's unity-Octane only issue.
I understand. I advice you to post the error at the Commercial support forums.
viewforum.php?f=10
Since it seems to be GPU related, the best option is to post the error in the GPU Support forum
viewforum.php?f=11
ChrisHekman
Re: GPU Failures
Postby coilbook » Wed Jan 23, 2019 11:25 pm
coilbook Wed Jan 23, 2019 11:25 pm
has anyone found out why. I am getting the same cuda errors for no reason. After these errors happen octane would reboot and continue rendering but after 5 times it is done and stops rendering.
coilbook
Re: GPU Failures
Postby fis715 » Thu Feb 28, 2019 10:24 pm
fis715 Thu Feb 28, 2019 10:24 pm
I just want my money back they keep charging my account and i cant use Octane i keep getting all gpu's failed error no response or help from Octane or Unity this is bad
fis715
Re: GPU Failures
Postby ChrisHekman » Fri Mar 01, 2019 9:37 am
ChrisHekman Fri Mar 01, 2019 9:37 am
fis715 wrote:I just want my money back they keep charging my account and i cant use Octane i keep getting all gpu's failed error no response or help from Octane or Unity this is bad
For license issues you should go to viewforum.php?f=10
On your GPU error issue. I have already asked you what your errors are, and if you could tell me when they occur, but you have not replied.
ChrisHekman
Re: GPU Failures
Postby rokklancnik » Mon Mar 04, 2019 4:52 pm
rokklancnik Mon Mar 04, 2019 4:52 pm
I have a similar problem. Except that the error on cuda says 999 and not 700. And something with the ORC subscription.. here is the LOG:
__________________________
Started logging on 04.03.19 17:48:58
OctaneRender Prime 4.00 (4000021)
ORC user subscription status could not be retrieved: The server returned a client-side error with HTTP code: 401
ORC subscription status cannot be found
CUDA error 999 on device 2: unknown error
-> failed to link file
device 2: failed to load OSL shader code:
error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
device 2: failed to compile module 0
___________________________
rokklancnik
Re: GPU Failures
Postby scottbroad » Tue Mar 12, 2019 9:33 am
scottbroad Tue Mar 12, 2019 9:33 am
Has there been any further development on this issue? ...
I can use Standalone ok but in Unity I still get the error:
CUDA error 999 on device 0: unknown error
device 0: failed to load OSL shader code:
device 0: failed to compile module 0
It would be good to be able to use Octane again in Unity ...
WIndows 10, GTX 1060 6Gb, Octane 4.02.1 - Unity 2018.3.8, OctaneRender Prime 4.00 (4000021)
Clive Broadhurst
Win 10-64bit, i7-3770K, 16Gb, GTX970
Revit 2015, Blender
scottbroad
Re: GPU Failures
Postby ChrisHekman » Tue Mar 12, 2019 10:10 am
ChrisHekman Tue Mar 12, 2019 10:10 am
Hi Scottbroad,
This is an nvidia driver issue. We are working on a build that fixes this, it should be out soon.
ChrisHekman
Previous
Return to Octane for Unity
Sun Feb 23, 2020 11:09 pm [ UTC ]
