Drive Octane Render programmatically from C# scripts
Forums: Drive Octane Render programmatically from C# scripts
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby Fanaen » Wed Jan 17, 2018 9:04 am
Fanaen Wed Jan 17, 2018 9:04 am
Hello!
The package Octane for Unity is really cool!
The company I currently work for could definitely use something like that. However, our use case doesn't seem to be covered at the moment.
We are currently using Unity mainly for the WebGL part and the scene/asset editing is done on the user end. In the long run, if we want to use Octane Render, we need a way to capture the scene either user-side (from WebGL) or server-side (headless editor) to trigger the rendering without manually opening the editor. The simplest solution is probably to use some C# scripts to load a given scene, load and configure the Octane Render, then send the job to the ORC.
So, a few questions:
  • Is this possible at the moment and how?
  • If not, is a documented C# API planned?
Best regards,
Fanaen
Fanaen
Re: Drive Octane Render programmatically from C# scripts
Postby Xhed » Mon Jan 22, 2018 9:14 am
Xhed Mon Jan 22, 2018 9:14 am
We don't have a properly functional C# API yet, but it is in the works.
- Rick
Xhed
Postby MattOstgard » Mon Jan 29, 2018 10:15 pm
MattOstgard Mon Jan 29, 2018 10:15 pm
Any idea what the time frame for this might be? I want to make some high to low mesh baking tools that would use unity-octane, but currently I can't really make them properly as it is now.
Also are there any plans to support displacement from unity materials without having to create a custom otoy material?
MattOstgard
Postby bmustata » Tue Feb 13, 2018 5:45 pm
bmustata Tue Feb 13, 2018 5:45 pm
Can we you have some basic support like start/pause render and render to texture?
Is it possible to access PBRRenderTarget in the current implementation?
bmustata
Postby bmustata » Wed Feb 14, 2018 6:40 pm
bmustata Wed Feb 14, 2018 6:40 pm
Do we have some kind of basic support like StartRender/PauseRender and Render To Texture?
or maybe we ca use GameObject.Find("PBR Render Target") or something similar?
Best regards,
Bogdan
bmustata
Postby Xhed » Fri Feb 16, 2018 9:31 am
Xhed Fri Feb 16, 2018 9:31 am
This is currently impossible. A proper C# API is in progress of being developed.
- Rick
Xhed
Postby bmustata » Fri Feb 16, 2018 9:42 am
bmustata Fri Feb 16, 2018 9:42 am
This sounds super!
bmustata
Postby anupamd » Thu Feb 22, 2018 8:53 pm
anupamd Thu Feb 22, 2018 8:53 pm
Hi, I'm very interested in the API as well.
my use-case is really runtime baking, or even better. something like a Differed Real-time Path Tracing such as what you see with Enscape.
https://enscape3d.com/wp-content/upload ... ferred.pdf
I know this is a very broad topic but
with the API, would I have enough functionality do something like this, at least the baking at runtime part?
anupamd
Return to Octane for Unity
Sat Jan 18, 2020 1:36 am [ UTC ]
