Moderator: ChrisHekman
xanathon wrote:Anything new that could help?
Failed: System.InvalidOperationException: Unexpected response from server.
UnityEngine.Debug:LogError(Object)
OctaneUnity.<>c:<Check>b__14_0(AuthCodeResponse)
UnityEditor.AsyncHTTPClient:Done(State, Int32)
xanathon wrote:If I try to login in the Octane PBR-window with the Octane account (clicking "Load Octane") I get the "unlicensed" popup. If I try to login with my Unity account nothing happens and I get the above mentioned error message in the console.
If you mean by "logged in" if I am logged into the Unity engine, the answer is yes. I tried "automatic" and "Prime", same result.
This cannot be a temporary server issue, as the problem still persists, just checked seconds ago. Unity is allowed to connect to external servers in the Win10 Firewall.
If I try to "Load Octane" with Unity selected the stacktrace is as follows:
- Code: Select all
Edit: Octane plugin says it's version is 1.1.0.1223
Edit: If I cancel the Octane licensing dialog the PBR window says Octane is active (Load button shows "unload") but all Octane menu items are still greyed out.
