Undo/Redo
Forums: Undo/Redo
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Undo/Redo
Postby Sergey91 » Wed Oct 10, 2018 9:00 pm
Sergey91 Wed Oct 10, 2018 9:00 pm
Hey guys!
Undo/Redo function doesn't work in Octane Plugin for Unity. This complicates work a lot. Could you fix it please?
Sergey91
Re: Undo/Redo
Postby Xhed » Thu Oct 11, 2018 9:12 am
Xhed Thu Oct 11, 2018 9:12 am
Hi Sergey,
is there a location where undo/redo doesn't work? We've added support for it, but it seems that we didn't do that everywhere properly.
- Rick
Xhed
Re: Undo/Redo
Postby Sergey91 » Thu Oct 11, 2018 4:44 pm
Sergey91 Thu Oct 11, 2018 4:44 pm
There is no particular location where it doesn't work, It doesn't work in general in Octane plugin for Unity. For example if I accidentally delete any node, I can't undo this action.
It is not even active (see attachments)
I'd appreciate if you could double-check things here.
Sergey91
Re: Undo/Redo
Postby Xhed » Fri Oct 12, 2018 1:46 pm
Xhed Fri Oct 12, 2018 1:46 pm
Your attachment isn't showing for me, it redirects me to Imgur's 404 page.
Where are you deleting a node? Are you referring to the Octane interface?
- Rick
Xhed
Re: Undo/Redo
Postby Sergey91 » Fri Oct 12, 2018 3:51 pm
Sergey91 Fri Oct 12, 2018 3:51 pm
Yes, exactly. As we're talking about Octane, I meant any action in Octane UI - delete node, make any adjustments to the materials inside Octane plugin, literally anything that is done through Octane's UI. Does it make more sense now?
Here's the missed image https://imgur.com/S2zaZ3Y
Sergey91
Re: Undo/Redo
Postby manusd » Fri Mar 19, 2021 11:01 am
manusd Fri Mar 19, 2021 11:01 am
I`ve got the same problem. Any solution to this?
manusd
Return to Octane for Unity
Wed Apr 24, 2024 1:24 am [ UTC ]
