G3 Lip Gloss Options do not work
Forums: G3 Lip Gloss Options do not work
Forum for discussing Redspec SSS.
Moderator: TRRazor
RedSpec SSS and TGX © RedSpec SSS
http://redspec-sss.com
Postby birdovous » Sat Feb 17, 2018 10:25 am
birdovous Sat Feb 17, 2018 10:25 am
I noticed this issue quite a while ago but as I'm not using G3 based figures that much (yeah I'm still mostly stuck using V4 based characters) I didn't give it much of a thought but still...
As the subject says, I noticed that the material options that should control the lip gloss effect do not really work. The problem is the same with both bump map and normal map based presets.
Basically, what is happening is, that the preset loads just fine, but if you check the Octane Render System messages, the following error gets shown, regardless of what level of gloss you select:
11:04:08.118: could not find file or directory 'C:\Program Files\RedSpecTGX\daz3d_genesis8fem\spec\g8f_lips_spec_higloss.jpg'
I did check my purchase history and it shows: RedSpec TGX tailored MK3 for Genesis 3 and 8 Females Item# TGX TAI MK2 (GEN3F)
So this should be OK. When I check the installation folder however, there is no daz3d_genesis8fem sub folder in it.
If I edit the loaded preset and manually change the lip gloss specular 'brick' to point to the texture spec texture map from the daz3d_genesis3fem then all works.
Also a funny thing that I just realized is, that when I download the purchased set of shaders, then the name of the archive that is downloaded is: redspec_tgx_tailored_mk3_gen3fems_gen8fems.zip
However, when I extract it, then it contains 2 files. One is an archive that should be extracted to DAZ content folder (and which correctly contains presets for both Gen3 and Gen8 female figures) and the other is an executable installer named redspec_tgx_tailored_mk3_gen3fems.exe which apparently installs (as it says in its name) just the G3 support assets to the C:\Program Files\RedSpecTGX which basically explains the missing daz3d_genesis8fem sub folder.
Or... I am genuinely confused... :D
Birdovous
Master: Core i7 2600K, 32GB RAM, 2x EVGA GTX Titan X (SC)
Slave: Core i5 4460, 16GB RAM, 2x EVGA 1080 Ti SC2
birdovous
Re: G3 Lip Gloss Options do not work
Postby TRRazor » Sat Feb 24, 2018 6:50 am
TRRazor Sat Feb 24, 2018 6:50 am
thank you, for reporting your findings.
Did you check if the problem persists with the latest update of the shaders?
I'm asking, because the installation routine definitely copies that file to the respective directory (just checked it).
Maybe a reinstall will help?
Regards
Noel
REALISTIC HUMAN SKIN SHADING - REDEFINED
RedSpec TGX Hair for Poser / DAZ Studio OctaneRender - OUT NOW visit http://redspec-sss.com/
TRRazor
Postby birdovous » Sat Feb 24, 2018 8:27 am
birdovous Sat Feb 24, 2018 8:27 am
Before I posted the report I did re-download the shader pack just to be sure.
The installation file contained in the archive is dated 23-12-2017.
Birdovous
birdovous
Postby TRRazor » Sat Feb 24, 2018 10:00 am
TRRazor Sat Feb 24, 2018 10:00 am
Okay, thanks.
I will investigate and will report back.
TRRazor
Return to Redspec SSS
Who is online
Wed Jan 29, 2020 7:59 am [ UTC ]
