External OSL Texture needs recompiling on doc load
Forums: External OSL Texture needs recompiling on doc load
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby pegot » Mon May 18, 2020 8:56 pm
pegot Mon May 18, 2020 8:56 pm
I see that in latest version of Octane Blender (2020.1 21.7) the issue with the disappearing input pins on OSL Text nodes has been fixed. However, I still have to recompile the script each time I load the file again. Is that normal? Do external OSL scripts always have to be recompiled each time the file is open?
Windows 10
4.2Ghz i7 7700k / 64 GB
AsRock SuperCarrier
GTX 1080 ti SC Black (wc)
GTX 1080 ti SC2 Hybrid
GTX 780 6 GB
Hackintosh OS X 10.14.3 - NOT able to use with Octane :(
3.5 Ghz Intel i7-3770K / 32 GB
Gigabyte GA-Z77X-UP5
GTX 770 4 GB
pegot
Re: External OSL Texture needs recompiling on doc load
Postby pegot » Mon May 18, 2020 9:51 pm
pegot Mon May 18, 2020 9:51 pm
I also just took the same external script and wrote it into the OSL node as an internal script - but it still needs recompiling on every new document load after closing Blender.
Windows 10
AsRock SuperCarrier
GTX 780 6 GB
GTX 770 4 GB
pegot
Postby linograndiotoy » Wed May 20, 2020 8:06 am
linograndiotoy Wed May 20, 2020 8:06 am
pegot wrote:I also just took the same external script and wrote it into the OSL node as an internal script - but it still needs recompiling on every new document load after closing Blender.
OSL nodes get compiled when you start the preview or a render.
linograndiotoy
Postby pegot » Wed May 20, 2020 5:47 pm
pegot Wed May 20, 2020 5:47 pm
linograndiotoy wrote:OSL nodes get compiled when you start the preview or a render.
That's not happening with my set up. I'm using the OSL blur shader. And I have to recompile it every time I close Bender and then upon that file again. Maybe the blur code is different than other OSL textures that causes this?
Windows 10
AsRock SuperCarrier
GTX 780 6 GB
GTX 770 4 GB
pegot
Postby linograndiotoy » Thu May 21, 2020 10:16 am
linograndiotoy Thu May 21, 2020 10:16 am
Can you please share a simple scene showing the issue? Thanks!
linograndiotoy
Postby pegot » Fri May 22, 2020 3:41 pm
pegot Fri May 22, 2020 3:41 pm
Ok. See attached blend file. The OSL node is part of the environment texture. It blurs a procedural texture.
OSL-Compile-Issue.zip
(514.35 KiB) Downloaded 16 times
Windows 10
AsRock SuperCarrier
GTX 780 6 GB
GTX 770 4 GB
pegot
Postby linograndiotoy » Sun May 24, 2020 12:36 pm
linograndiotoy Sun May 24, 2020 12:36 pm
I've tried the scene in the current internal build. OSL nodes are compiled correctly, but the whole scene doesn't render on my system. We'll take a deeper look.
linograndiotoy
Postby pegot » Thu Jun 04, 2020 1:08 am
pegot Thu Jun 04, 2020 1:08 am
This appears fixed with the latest 21.8 release. Thanks!
Windows 10
AsRock SuperCarrier
GTX 780 6 GB
GTX 770 4 GB
pegot
Postby linograndiotoy » Thu Jun 04, 2020 9:02 am
linograndiotoy Thu Jun 04, 2020 9:02 am
You're welcome!
linograndiotoy
Return to Bug Reports
Thu Aug 13, 2020 12:33 am [ UTC ]
