[21.7] Command line rendering issue
Forums: [21.7] Command line rendering issue
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby kabakZ » Mon May 18, 2020 8:28 pm
kabakZ Mon May 18, 2020 8:28 pm
Only the first frame of animation or frame sequence is rendered correctly. Next frame crashes the OctaneServer.
Default Blender scene with a cube
Octane 21.7, Win 10 x64
CMD error
kabakZ
Re: [21.7] Command line rendering issue
Postby kabakZ » Mon Jun 08, 2020 7:35 pm
kabakZ Mon Jun 08, 2020 7:35 pm
I can’t believe that no one is using command line rendering instead of UI, and no one has faced this problem yet.
kabakZ
Postby linograndiotoy » Wed Jun 10, 2020 8:14 am
linograndiotoy Wed Jun 10, 2020 8:14 am
kabakZ wrote:I can’t believe that no one is using command line rendering instead of UI, and no one has faced this problem yet.
Does this also happen in the current 21.8 version?
linograndiotoy
Postby kabakZ » Thu Jun 11, 2020 6:31 pm
kabakZ Thu Jun 11, 2020 6:31 pm
Yes, this also happens in the current 21.8 version.
Here are the command line args, can be tested on the startup cube scene:
"C:\Program Files\BlenderOctane\blender.exe" --background "C:\Proj\test.blend" --render-output "C:\Proj\f_" -f 0   <<-- OK
"C:\Program Files\BlenderOctane\blender.exe" --background "C:\Proj\test.blend" --render-output "C:\Proj\f_" -f 1   <<-- OctaneServer crash with Octane Kernel error
or
"C:\Program Files\BlenderOctane\blender.exe" --background "C:\Proj\test.blend" --render-output "C:\Proj\f_" -a    <<-- only the first frame of the animation renders fine, but next frame will crash the process
kabakZ
Return to Bug Reports
Thu Aug 13, 2020 12:52 am [ UTC ]
