[20.3] SVG import crash
Forums: [20.3] SVG import crash
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby J.C » Wed Feb 19, 2020 12:59 pm
J.C Wed Feb 19, 2020 12:59 pm
Importing an SVG file results in an error:
bpy.ops.object.delete(use_global=False)
Deleted 1 object(s)
bpy.context.space_data.recent_folders_active = 1
bpy.context.space_data.recent_folders_active = 0
Traceback (most recent call last):
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\__init__.py", line 59, in execute
    return import_svg.load(self, context, filepath=self.filepath)
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 1882, in load
    load_svg(context, filepath, do_colormanage)
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 1872, in load_svg
    loader.parse()
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 1085, in parse
    ob = parseAbstractNode(node, self._context)
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 1856, in parseAbstractNode
    ob.parse()
    ob.parse()
    ob.parse()
    ob.parse()
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 1134, in parse
    pathParser = SVGPathParser(d, self._styles['useFill'])
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 508, in __init__
    self._data = SVGPathData(d)
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\import_svg.py", line 420, in __init__
    token, last_char = read_float(d, i)
  File "C:\Program Files\BlenderOctane20_7\2.81\scripts\addons\io_curve_svg\svg_util.py", line 88, in read_float
    raise Exception('Invalid float value near ' + text[start_index:start_index + 10])
Exception: Invalid float value near .93,4.18,5
The same file is imported fine in official blender builds.
System – Windows 11
J.C
Re: [20.3] SVG import crash
Postby linograndiotoy » Thu Feb 20, 2020 9:08 am
linograndiotoy Thu Feb 20, 2020 9:08 am
Can you attach your SVG file reproducing the crash?
linograndiotoy
Postby J.C » Fri Feb 21, 2020 10:14 am
J.C Fri Feb 21, 2020 10:14 am
linograndiotoy wrote:Can you attach your SVG file reproducing the crash?
Sure, here it is:
svg_sample.zip
(356 Bytes) Downloaded 165 times
System – Windows 11
J.C
Postby ChrisH » Fri Feb 21, 2020 4:31 pm
ChrisH Fri Feb 21, 2020 4:31 pm
J.C. what Blender version(s) did you test with?
I tested with 2.80 and 2.82, both works. I downloaded 2.81 from blender.org, and then I couldn't import the SVG, so it could be specific to 2.81..
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
ChrisH
Postby linograndiotoy » Sun Feb 23, 2020 9:42 am
linograndiotoy Sun Feb 23, 2020 9:42 am
Yes, works fine here in 2.82.
linograndiotoy
Postby J.C » Mon Feb 24, 2020 8:06 am
J.C Mon Feb 24, 2020 8:06 am
ChrisH wrote:J.C. what Blender version(s) did you test with?
I tested latest 2.81a and up. They import the SVG files without any issue.
System – Windows 11
J.C
Postby linograndiotoy » Mon Feb 24, 2020 11:21 am
linograndiotoy Mon Feb 24, 2020 11:21 am
Perfect then.
linograndiotoy
Return to Bug Reports
Users browsing this forum: No registered users and 5 guests
Thu Apr 25, 2024 4:22 pm [ UTC ]
