[20.6] Triplanar Projection node doesn't work
Forums: [20.6] Triplanar Projection node doesn't work
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby grimm » Sat Dec 21, 2019 10:11 pm
grimm Sat Dec 21, 2019 10:11 pm
I tried to use the Triplanar Projection node, but it doesn't work and also does not show any controls at all, like blend angle? Box projection does work, but I don't get the same amount of control over the projection. Thanks,
Jason
Linux Mint 19 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 440.64
grimm
Re: [20.6] Triplanar Projection node doesn't work
Postby DrawFun » Fri Jan 10, 2020 10:41 am
DrawFun Fri Jan 10, 2020 10:41 am
Hello grimm,
Thanks for your post.
The Triplanar projection works in conjunction with a Triplanar Tex. And the settings like blend angle are in the Triplanar Tex as well. You can find it by search or under the Octane Procedural sub-menu.
Cheers,
DrawFun
DrawFun
Postby grimm » Sat Jan 11, 2020 5:39 pm
grimm Sat Jan 11, 2020 5:39 pm
Thanks Drawfun, I got it working. My only problem now is that I can't get it to work with displacement.
I like that the Triplanar Tex node is very flexible, but it would be nice to have a single texture input pin that would just place the image on all 6 planes at once.
Jason
grimm
Postby J.C » Sat Jan 11, 2020 11:30 pm
J.C Sat Jan 11, 2020 11:30 pm
grimm wrote:... My only problem now is that I can't get it to work with displacement.
Jason
You need to use either Vertex displacement or use bake node to drive the Texture displacement.
Texture displacement only works with bitmap textures on UV'ed meshes or with baked textures.
CPU – i7 8700k 4.8Ghz + 64GB RAM, GPUs: 4xRTX 2080, 2xGTX 980 Ti.
System – Windows 10, Octane 4-2020, Blender Plugin 17.x-21.x
J.C
Postby grimm » Sun Jan 12, 2020 1:34 am
grimm Sun Jan 12, 2020 1:34 am
Thanks J.C., that worked. :)
grimm
Return to Bug Reports
Users browsing this forum: einarmartinsen and 1 guest
Mon Jun 01, 2020 11:41 pm [ UTC ]
