by DrawFun » Tue Sep 10, 2019 9:13 pm
DrawFun
This is working in my tests.
Could you please check if you use the relative path with the pattern of blender? Thanks.
-If you select a path from the file selector, please make sure to tick on the "Relative Path" option on the left
-If you type the path manually, please make sure the file path is starting with "//"(e.g. "//vdb\smoke.vdb"), which is the relative path tag for blender to recognize
