Shading errors (W/ Universal Shader) in 17.5 [TEST]
Forums: Shading errors (W/ Universal Shader) in 17.5 [TEST]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby ChrisH » Tue Mar 05, 2019 7:20 pm
ChrisH Tue Mar 05, 2019 7:20 pm
Hi!
Downloaded and installed 17.5 today, but discovered a problem when rendering my "scene" (it's not finished and only a clay shader so far), where black areas appeared on the model (similar to what might appear if you have overlapping meshes).
This doesn't appear in the Stable version (v16.3.3), neither did it in the previous Test version (17.4).
I isolated just the main mesh (so there's just 1 object + camera in the active layers, made sure there was no overlapping geometry etc.
As I'm writing this I did some more tests, creating a new mesh etc, and:
It appears to only happen on faces in the Y-axis (rotating it slightly and it goes away), and only with the Universal Shader (If I switch to Diffuse the black areas disappear).
So it might be a Octane problem (rather than OcatneBlender)!? But I don't know where to report that!
(*Using the Test builds to speed up animation rendering..)
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Stand Alone + Blender Plugin user
ChrisH
Re: Shading errors (W/ Universal Shader) in 17.5 [TEST]
Postby ChrisH » Tue Mar 05, 2019 7:55 pm
ChrisH Tue Mar 05, 2019 7:55 pm
I created a new file to see if I could recreate the problem, which I couldn't, at first!
My new mesh didn't show the same problems, I tried to copy each setting to see what might trigger it, but nothing.
I imported the objects from the other scene, gave them all the same materials but the new object didn't show the same problem (while the old ones did).
Then I UV-unwrapped the new object, and: there it was (just not as prominent, but also not in a single direction), the new object exhibited the same problems!
Then I changed the UV mapping of the other objects, and the black faces shifted!
NB: There's only an Universal material, no other nodes or textures!
I attached my test file!
OctaneTest1.blend
(5.34 MiB) Downloaded 14 times
ChrisH
Postby J.C » Thu Mar 07, 2019 5:27 pm
J.C Thu Mar 07, 2019 5:27 pm
Looks like an engine bug. In latest standalone RC6 it it sthe same.
CPU – i7 8700k 4.8Ghz + 64GB RAM, GPU – 2xGTX 980 Ti, 2xRTX 2080
System – OS X 10.12.6, Windows 10, Octane 4/2018, Blender Plugin 16.x.x and 17.x
J.C
Return to Bug Reports
Sun Sep 15, 2019 3:57 pm [ UTC ]
