OctaneRender™ for Blender 2018.1.3 - 17.10 [STABLE]
Forums: OctaneRender™ for Blender 2018.1.3 - 17.10 [STABLE]
Postby azen » Wed Sep 18, 2019 5:38 am
azen Wed Sep 18, 2019 5:38 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
FIXES SINCE LAST RELEASE
  • Refactor object layer data: now they are moved from mesh data panel to object data panel
  • Fixes in baking layer settings
    • Complete the baking layer transform setting under "Property-Object-Baking Layer", which will be the correct place for changing baking transform
    • Remove the baking layer setting under "Property-Render Layer-Baking Layer"
    • Use "Property-Camera-Baking-Baking group ID" to change the baking group in the scenes
  • Fixes in kernel settings
    • Fix wrong gray UI
    • Hide unnecessary options in different kernels
    • Remove deprecated G.I. modes
  • Fixes in VDB render
    • Fix VDB black box issue
    • Fix VDB update issue under preview render
  • Fix OSL update issue under preview render
  • Fix particle motion blur issue
  • Fix global mesh smooth issue
  • Disable octane export passes unless cryptomatte is on
  • Make it more robust when handling local db path
  • Fix warning about "use_adaptive_subdivision"
You can read about new features of OctaneRender™ 2018.1.3 here:
viewtopic.php?f=24&t=71703
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 17.10 (2.79)
Octane Server - 17.10
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.10 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v17.10 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Mon Jul 06, 2020 9:52 am [ UTC ]
