OctaneRender™ for Blender 4.04 - 16.4 [OBSOLETE]
Posted: Wed May 08, 2019 4:12 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 4.04 here:
viewtopic.php?f=24&t=71375
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 16.4 (2.79)
Octane Server - 16.4
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v16.4 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v16.4 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Updated sdk to 4.04
- Supported viewport material color("Properties-Material-Settings")
- Supported to save material as OctaneDB("Material-Settings-Save As OctaneDB")
- Supported camera mapped feature in Image Nodes
- Supported to customize LocalDB path( "User Preference-Octane Render-Octane LocalDB Path")
- Used blender temp folder("User Preference-File-Temp") to save octane temp files
- Added "Linear space invert" for texture image nodes
- Added "Toon shadow ambient"("Render-Octane kernel-Toon shadow ambient")
- Added "Cast shadow" for toon lights
- Added normal and bump for coating and sheen in universal material
- Added simplify settings
- Added volume properties in Material panel
- Included alembic feature for osx/linux builds
- Fixed some disordered issues/crashes in LiveDB material
- Fixed Metal/Toon/Universal material support in LiveDB material
- Fixed unwanted reflection filter pass in exported orbx
- Optimized material upload - now materials in inactive scenes would not be uploaded
- Change "Octane LiveDB" in windows menu to "OctaneDB" as it contains both localDB and liveDB
Windows
Linux
Installation:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
