OctaneRender™ for Blender 2018.1.2 - 17.7 [OBSOLETE]
Posted: Fri Apr 26, 2019 2:25 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 2018.1.2 here:
viewtopic.php?f=24&t=71406
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 2018.1.2 - 17.7 (2.79)
Octane Server - 2018.1.2 - 17.7
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v2018.1.2 - 17.7 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v2018.1.2 - 17.7 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Updated to 2018.1.2
- Reorganize kernel UI layout
- Have Smoothing on for newly added materials
- Optimized object upload process(Turn it on at "User Preference-Add ons-Octane-Optimized Object Generation Mode")
- Now octane will save passes as exr to "Render-Output" folder(to fix the cryptomatte pass export issue)
- Use blender temp folder("User Preference-File-Temp") to save octane temp files
- Support "Camera Mapped" in alpha image and float image
- Add "Toon shadow ambient"("Render-Octane kernel-Toon shadow ambient")
- Add "Cast shadow" for toon lights
- Add volume properties in Material panel
- Fix rendering issue when objects are hidden
- Fix the animation export issue
- Fix unwanted reflection filter pass in exprted orbx
Windows
Linux
Installation:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
