OctaneRender™ for Blender 2018.1 RC4 - 17.4 [OBSOLETE]
Forums: OctaneRender™ for Blender 2018.1 RC4 - 17.4 [OBSOLETE]
Postby azen » Mon Feb 25, 2019 11:43 pm
azen Mon Feb 25, 2019 11:43 pm
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
  • Upgraded to 2018.1 RC4
  • Supported orbx proxy (now we are able to import external orbx as a proxy)("Properties-Data-Orbx properties-Orbx File Path")
  • Supported to change target node tree when fetching livedb material
  • Supported viewport material color("Properties-Material-Settings")
  • Added "Linear space invert" for texture image nodes
  • Included alembic feature for osx/linux builds
  • Prevented crash when failing to overwrite orbx file
FIXES SINCE LAST RELEASE
  • Fixed motion blur render issue under the preview navigation
  • Fixed material preview render failure
  • Fixed emission issue in mix material
KNOWN ISSUES
  • Due to the current motion blur mechanism, animation for orbx proxy does not work when motion blur enabled
  • Displacement does not work with vertex color/float attributes in the current build(engine team has plans to support it)
You can read about new features of OctaneRender™ 2018.1 RC4 here:
viewtopic.php?f=33&t=70675
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 17.4 (2.79)
Octane Server - 17.4
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.4 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v17.4 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Sun Sep 22, 2019 4:06 pm [ UTC ]
