OctaneRender™ for Blender 2018.1 - 17.2 [OBSOLETE]
Forums: OctaneRender™ for Blender 2018.1 - 17.2 [OBSOLETE]
Postby azen » Mon Jan 28, 2019 9:57 pm
azen Mon Jan 28, 2019 9:57 pm
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
  • Optimized node graph rendering
  • Supported dragging into image feature for world texture
  • Added post processing in render layer
  • Removed legacy livedb
FIXES SINCE LAST RELEASE
  • Fixed memory corruption under some specific resolutions
  • Fixed Transmission input issue in Diffuse Material
  • fixed resharpable mesh vertices error
  • Fixed light mesh update error
  • Fixed probabilistic motion blur update failure
  • Fixed camera move probabilistic render error under motion blur
  • Fixed camera motion blur rendering failure when changing shutter alignment
  • Fixed denoies passes missing error in render layer
  • Fixed the inverted inputs in mix material
  • Fixed compatibility check_update issue
  • Fixed render failure when area light size = 0
  • Fixed misspelling errors
You can read about new features of OctaneRender™ 2018.1 RC1 here:
viewtopic.php?f=33&t=70196
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 17.2 (2.79)
Octane Server - 17.2
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.2 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v17.2 OSX Autoinstaller
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Fri Apr 03, 2020 6:44 am [ UTC ]
