OctaneRender™ for Blender 4.01.1 - 16.3.1 [OBSOLETE]
Posted: Tue Dec 18, 2018 5:20 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
New LiveDB:
The new Octane LiveDB can be found under "Windows-Octane LiveDB". Right click on the target material and then click import to start download. After the download finished, the liveDB material will be put/replace current material. You are able to find it under the material panel(this is same as old LiveDB System).
As this is a totally new system for blender, the old LiveDB is still there "to be on safe side".
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 4.01.1 here:
viewtopic.php?f=24&t=69925
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 16.3.1 (2.79)
Octane Server - 16.3.1
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v16.3.1 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.3.1 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.3.1 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Upgraded SDK to 4.01.1
- Refactored LiveDB and supported LocalDB ("Windows-Octane LiveDB")
- Added "keep instance power" in BlackBodyEmission and TextureEmission
- Added "Blend cube transform" and "Coordinate space" in TriplanarTexture
- Added "Omega" in RidgedFractalTexture
- Added render priority feature
- Stored gpu device settings when closing the setting panel
- Removed old gpu device settings
- Supported texture for "Ground albedo" and "Ground Emission" in planetary environment
New LiveDB:
- Fixed issue in OSL Projection
- Fixed issue in deep image
- Fixed nodegraph issue when " Node Graph Upload Optimization" is on
- Fixed crash when "Empty GPU After Rendering" feature is on
- Fixed area light issue
- Fixed cast shadow issue in emission textures
- Fixed crash when open livedb without object selected
Windows
Linux
Installation:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
