OctaneRender™ for Blender 3.08.5 - 15.3.4 [STABLE]
Forums: OctaneRender™ for Blender 3.08.5 - 15.3.4 [STABLE]
Postby azen » Thu Nov 08, 2018 11:40 pm
azen Thu Nov 08, 2018 11:40 pm
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
NEW FEATURES SINCE LAST RELEASE
  • Upgrade to 3.08.5
  • Add option to support untonemapped image rendering with camera imager ("Render" - "Render" - "Prefer tonemap if applicable")
  • Add option ("User Preference" - "Add-ons" - "OctaneRender Engine" - "Generate Default UVs") to generate default UV Map when creating preset primitives
  • Force to switch to solid mode when clicking "Stop Render and Empty GPU"
  • Support "texture type" and "sample per pixel" in baking texture node
  • Add button to reload image for all image texture nodes
  • Rename float tex to grayscale tex to make it better understanding
FIXES SINCE LAST RELEASE
  • Fix particle texture setting missing
  • Fix camera border mode render issue
  • Fix direction issue in toon light
  • Fix update failure when deleting toon lights
  • Fhange the out tex type from shader to vector for float value node and int value node
  • Fix default power value from 0.9 to 1 for all image texture nodes
  • Fix maximum value error of parallel samples and max tile samples
  • Fix transform node render failure in nodegraph
  • Fix image sequence issue
You can read about new features of OctaneRender™ 3.08.5 here:
viewtopic.php?f=24&t=69127
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 15.3.4 (2.79)
Octane Server - 15.3.4
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.3.4 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.3.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.3.4 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Thu Apr 25, 2024 11:32 am [ UTC ]
