OctaneRender™ for Blender 4.0 RC2 - 16.2.2 [OBSOLETE]
Forums: OctaneRender™ for Blender 4.0 RC2 - 16.2.2 [OBSOLETE]
Postby azen » Wed Sep 05, 2018 5:52 am
azen Wed Sep 05, 2018 5:52 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
  • Upgrade to V4 RC2
  • Support backward compatibility for mid level displacement
  • Support projection in OSL node
  • Support empty tile color in UDIM node
  • Add Planetary Environment type
FIXES SINCE LAST RELEASE
  • Add missing refract channel in render layer node
  • Optimize environment texture update
  • Fix material missing issue in particle system with inactive source objects
  • Remove denoise refraction
  • Environment power can be down to 0
  • Fix the order of UV generation list in UDIM node
  • Fix render layer mode error
  • Fix probabilistic denoise failure
  • Fix ior error in universal material
  • Rename "Specular color" to "Specular" in universal material
  • Rename "Artistic" to "Default" in universal material
You can read about new features of OctaneRender™ 4.0 XB4 here:
viewtopic.php?f=33&t=68283
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 16.2.2 (2.79)
Octane Server - 16.2.2
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.2 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.2 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.2 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Users browsing this forum: azen and 2 guests
Wed Sep 18, 2019 10:28 pm [ UTC ]
