OctaneRender™ for Blender 3.08 - 15.2.4 [OBSOLETE]
Posted: Fri Jun 15, 2018 2:15 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
NEW FEATURES SINCE LAST RELEASE
FIXES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 15.2.4 (2.79)
Octane Server - 15.2.4
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v15.2.4 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.2.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.2.4 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- Upgrade SDK to 3.08.1
- Support environment texture backward compatibility
- Support enum options backward compatibility
- Bring back the preview camera imager settings(“3D View”-“Octane Camera Imager(Preview Mode)”)
- Provide an override option to use preview camera imager in all cases
- Optimize updates of environment texture
- Fix version number verification failure in some platforms
- Fix livedb specular material crash
- Fix some compilation optimization failures based on render layer and visibility
- Fix a crash in external openvdb
- Fix preview render failure in scenes without cameras
- Try to fix crash when rendering with unsaved file under osx
Windows
Linux
Installation:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
