OctaneRender™ for Blender 3.08 - 15.1 [OBSOLETE]
Forums: OctaneRender™ for Blender 3.08 - 15.1 [OBSOLETE]
Postby azen » Tue Apr 03, 2018 2:23 am
azen Tue Apr 03, 2018 2:23 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
This is a TEST version, so be prepared to have some issues. Don't use it for production.
NEW FEATURES SINCE LAST RELEASE
  • Integrate 2.79a
  • Upgrade to 3.08RC2
  • Add new passes: irradiance, light direction, volume, volume mask, volume emission, volume z depth front, volume z depth back
  • Add OSL baking camera
  • Add irradiance mode
  • Add sheen pin nodes to metal/glossy materials
  • Add new IOR for to the metallic material
  • Support geometry mesh animation modifier
FIXES SINCE LAST RELEASE
  • Remove the word Octane inside menu
  • Fix environment texture rename bug
  • Set default value of "power" in Octane Image Texture to 1.0
  • Add refresh gpu button to enable users to update gpu lists
  • Hide render layer in octane engine
  • Merge interactive/render camera imager setting into one
  • Keep compatibility with old version for response curve
  • Rename "Max samples" in Octane Render Pass Setting to "Info pass max samples"
  • Support user-customized default material(“User Preference” – “Add-ons” – “OctaneRender Engine” – “Preferences” – “Default Material Type”)
  • Do not update shader/object which is hide in "Outliner"
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 15.1 (2.79)
Octane Server - 15.1
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.1 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.1 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.1 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Sun Jul 05, 2020 8:14 pm [ UTC ]
