OctaneRender™ for Blender 3.07 - 13.4 [OBSOLETE]
Posted: Tue Nov 14, 2017 4:22 am
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
Here is a basic overview of our Development plans for the near future. Additional feedback is welcome:
NEW FEATURES SINCE LAST RELEASE
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
viewtopic.php?f=33&t=62395
The installation consists from two parts:
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 13.4 (2.78a)
Octane Server - 13.4
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v13.4 Linux
OSX
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v13.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v13.4 OSX ZIP
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
- - Blender Octane Edition 14.x: Integrating Blender 2.79
- - Blender Octane Edition 15.x: Support for upcoming Octane 3.08 rendering core
- New stable 3.07 engine support implemented.
- Fixed crash when switching materials with scenes created in previous versions
- Fixed OpenVDB problem in linux version
- Fixed LiveDB thumbnails problem (upside down and bluish tint)
- Fixed smoke renders problem
- Added rpath for linux build(try to resolve lib dependency problem in linux)
- Fixed missing IES texture problem
- Fixed missing distribution texture problem
- Added Triplanar projection node
- Fixed frozen window when querying LiveDB data that is not ready yet
Windows
Linux
Installation:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX
Installation:
DOWNLOAD
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
