1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
- Added enable/disable checkbox to imager (for the case you don't want to use Blender's standard instruments on the top of untonemapped render result). Makes sense for final render only. The live-preview render is always tonemapped, 'cause Octane core has no "untonemapped" mode for non-HDR renders.
Installation:
- Just run autoinstaller file.
DOWNLOAD
Blender Octane Edition - v9.11 OSX
DEMO is available..
Blender Octane Edition DEMO - v9.11 OSX
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
