Render Layer pass bug[SOLVED]
Posted: Tue May 23, 2017 9:07 am
The separate "Layer Reflections" pass name is wrong, it should not use the
BUG :
Separate passes should just use the user-defined Exr Channel names so these mistakes with the hard-coded names could not happen.
_refl
suffix, which is already used for the "Reflection" pass.BUG :
Layer Reflection pass
overrides the Reflection pass
at render time.Separate passes should just use the user-defined Exr Channel names so these mistakes with the hard-coded names could not happen.
