OctaneRender for Maya 2020.1xb3-17.7 [OBSOLETE]
PostPosted: Thu Feb 13, 2020 12:48 am
by JimStar
Forum rules:
NOTE: The software in this forum thread is not 100% reliable, this is a development build and is meant for testing by experienced octane users. If you are a new octane user, we recommend to use the current stable release.
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSE THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya®: OctaneRender™ 2020.1
Maya® Version Requirements
This release will work with Maya® Versions 2017, 2018, 2019 and 2020 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 2020.1 are here:
OctaneRender Standalone 2020.1 XB3
Changes since versions 17.6:
  • Implemented the edges' and vertices' crease support for Maya's mesh objects when using Octane's OpenSubD mode.
KNOWN ISSUES:
  • "CUDA error 700" and other CUDA errors are expected to happen from time to time: these are the Octane engine's bugs. Should be fixed with later SDK/Standalone versions...
  • Due to some inconsistency on the rendering engine level the builtin-scriptgraph nodes are not going to be present in the plugin. At least at this stage.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
Re: OctaneRender for Maya 2020.1xb3-17.7 [BETA]
PostPosted: Fri Feb 14, 2020 2:50 am
by hgarrou
This is a terrific update. I'd been secretly wanting crease support. Thanks!!
PostPosted: Fri Feb 14, 2020 5:08 pm
by p3taotoy
Trying to load the plugin in Maya 2020
// Error: file: /Applications/Autodesk/maya2020/Maya.app/Contents/scripts/others/pluginWin.mel line 317: dlopen(/Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/plug-ins/OctanePlugin.bundle, 1): Library not loaded: @executable_path/libIMFbase.dylib Referenced from: /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/plug-ins/OctanePlugin.bundle Reason: image not found (OctanePlugin)
ANy ideas?
THanks
PostPosted: Fri Feb 14, 2020 5:34 pm
by p3taotoy
If this helps
with auto load selected in the plugin manager for Octane
The script editor gives this error on launching maya after a fresh plugin instal
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
// Error: file: /Applications/Autodesk/maya2020/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 35: Unable to dynamically load : /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/plug-ins/OctanePlugin.bundle
Reason: image not found //
// Error: file: /Applications/Autodesk/maya2020/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 35: dlopen(/Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/plug-ins/OctanePlugin.bundle, 1): Library not loaded: @executable_path/libIMFbase.dylib
Reason: image not found (OctanePlugin) //
PostPosted: Sat Feb 15, 2020 4:50 am
by JimStar
p3taotoy
Can't check it right now from home - Saturday here...
But are you sure your Maya 2020 installation is not corrupted and has the /Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/libIMFbase.dylib file in it?
Looks like this library file (required by Octane) is not loaded by Maya for some reason...
PostPosted: Sat Feb 15, 2020 3:08 pm
by p3taotoy
Thanks for replying on your Saturday mate.
Yeah you are correct... not there.
I'll try a reinstall and see what I get aye.
Appreciated.
Peter
PostPosted: Sat Feb 15, 2020 8:39 pm
by p3taotoy
Well that is a mystery... complete clean uninstall of ALL autodesk products.
Freshly downloaded Mac osx 2020 ( I am not aware of any upgrades yet are you?)
Same errors and that file you mention is not there.... I know it might be weird but can you zip yours and I'll put it in there to see what that does.... I realize yours may already be specific to your machine etc but I am wondering if a fresh install of the Maya Otoy plugin will overwrite the appropriate lines etc.
Just an idea cause I have no clue why this would be specific to my Mac Powerbook 15" 2017
High Sierra 10.13.6
Says my Nvidia driver is up to date: 387.10.10.10.40.105 last check 02/15/2020
This is a long shot... do you think an Nvidia card needs to be loaded and running during the install process? The file does not seem to be nvidia related... and come to think of it I did a fresh install with two 1080s hooked up and rendering fine in the standalone.
Welcome any ideas come work week.
Peter
PostPosted: Sun Feb 16, 2020 1:52 am
by JimStar
I don't have Maya 2020 and its SDK at home, but I have a suspicion that Autodesk might have excluded this library from Maya 2020 builds, spreading its functionality between other libs... I'll check it on Monday. If this is the case - I'll release a fix for OSX soon, getting rid of this issue... You can use Maya 2019 on OSX before this happens (I think Tuesday or Wednesday) - 'cause I would like to include another nice thing into the next beta release, which I'm working on right now...
PostPosted: Sun Feb 16, 2020 3:06 am
by p3taotoy
Thanks mate.
Appreciate the fix when you get to it.
Peter
