OctaneRender® for Maya® 3.05.3 - 9.22 [OBSOLETE]
Forums: OctaneRender® for Maya® 3.05.3 - 9.22 [OBSOLETE]
Moderator: JimStar
Postby JimStar » Tue Jan 17, 2017 10:53 pm
JimStar Tue Jan 17, 2017 10:53 pm
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=58640
CHANGES SINCE THE PREVIOUS VERSION
  • Relaxed the requirement of unique transform names for Maya versions including and later than 2016.
  • Fixed the region rendering bug.
Windows
DOWNLOAD
OctaneRender for Maya 9.22
OctaneRender for Maya DEMO 9.22
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.22 Linux
OctaneRender for Maya DEMO - 9.22 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.22 OSX
OctaneRender for Maya DEMO - 9.22 OSX
JimStar
Re: OctaneRender® for Maya® 3.05.3 - 9.22 [OBSOLETE]
Postby p.jsi » Fri Jul 14, 2017 1:53 pm
p.jsi Fri Jul 14, 2017 1:53 pm
Hi there,
The region render bug for maya still exists in terms of whenever you reopen render view you would have to check and uncheck 'pick focus region'. If its off shouldn't render region already work when you open render view the next time?
I am using the 3.06.4_11.7
p.jsi
Return to Releases
Sun Jan 17, 2021 7:02 am [ UTC ]
