Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
CHANGES SINCE THE PREVIOUS VERSION
- Imporved a virtual material consistency when rendered on different machines. This will work OK only in Maya versions starting from 2016, 'cause it uses some new functionality of it (the scenes must be saved from these versions too).
DOWNLOAD
OctaneRender for Maya 3.04.5 - 9.7
OctaneRender for Maya DEMO 3.04.5 - 9.7
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=57660
Yours,
The OctaneRender™ Team.
