OctaneRender® for Maya® 2.24.2 - 7.14 Linux [OBSOLETE]
Forums: OctaneRender® for Maya® 2.24.2 - 7.14 Linux [OBSOLETE]
Moderator: JimStar
Postby JimStar » Tue Nov 10, 2015 3:40 am
JimStar Tue Nov 10, 2015 3:40 am
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses, just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
CHANGES SINCE THE PREVIOUS VERSION
  • Added "Save composite EXR file" setting to "Additional" rollout of Octane settings. If set - the multilayer image file will be saved, if not set - the separate files will be saved for each pass. In the case of subframe motion blur is enabled - always the separate image files will be saved.
  • Added "Enable layers", "Invert layers" and "Active layer ID" parameters to Octane batch render command line. You can use the command line now to batch-render different Octane object layers.
  • Fixed OpenSubDiv sharpness bug: in some cases the setting did not affect the render result.
  • Minor fixes and improvements...
Installation:
- Just run the installer to see its command line keys.;)
DOWNLOAD
OctaneRender for Maya - v7.14 Linux (19.5MB autoinstaller file)
OctaneRender for Maya - v7.14 Linux DEMO (18.6MB autoinstaller file)
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
JimStar
Re: OctaneRender® for Maya® 2.24.2 - 7.14 Linux [OBSOLETE]
Postby JimStar » Mon Feb 22, 2016 3:31 am
JimStar Mon Feb 22, 2016 3:31 am
Next version HERE.
JimStar
Return to Releases
Tue Dec 01, 2020 3:08 pm [ UTC ]
