OctaneRender for Maya 2021rc2-20.5 [OBSOLETE]
Forums: OctaneRender for Maya 2021rc2-20.5 [OBSOLETE]
Moderator: JimStar
Postby JimStar » Wed Sep 22, 2021 5:51 am
JimStar Wed Sep 22, 2021 5:51 am
Forum rules:
NOTE: The software in this forum thread is not 100% reliable, this is a development build and is meant for testing by experienced octane users. If you are a new octane user, we recommend to use the current stable release.
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSE THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya®: OctaneRender™ 2021
Maya® Version Requirements
This release will work with Maya® Versions 2018, 2019, 2020 and 2022 64-bit on Windows, Linux and macOS operating systems.
Changelog and the installers for Octane Standalone 2021 are here:
OctaneRender Standalone 2021.1 RC2
Changes since 20.4:
  • Implemented the support of variable-sized particles for Bifrost. Render settings are now moved to rendering section of Bifrost shape-node.
    - Simulated components (volume/SDF, particles, foam particles) are only enabled/rendered by Octane if the respective component's medium/material is connected in the "Octane" rollout of Bifrost node.
    - Because Octane engine does not support (at least so far) dynamic differently-sized voxels (like Bifrost does), only one deepest level of Bifrost simulation will be rendered by Octane.
    - Bifrost API has a bug - because of it in some cases SDF or volume component is rendered in a wrong position (while foam/particles are always in correct positions). If this happens, the only way to workaround it is to disable this volume/SDF component (unconnect Octane medium/material from a volume) and enable Bifrost meshing. This will only work for SDF though, because the volume obviously can not be rendered as a mesh. Bifrost developers confirmed this is a Bifrost problem. Not sure if they're going to fix it...
Known issues:
  • The MacOS version of Octane SDK is still not available.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
JimStar
Re: OctaneRender for Maya 2021rc2-20.5 [BETA]
Postby p3taotoy » Wed Oct 13, 2021 8:41 pm
p3taotoy Wed Oct 13, 2021 8:41 pm
I am able to export an orbx and this runs fine in the standalone
But no rendering view in octane viewer window
No errors in script or no freezes... just blue screen
Using Maya 2022.1
Cut ID: 202106180615-26a94e7f8c
Anyone else have this issue?
p3taotoy
Postby BK » Thu Oct 14, 2021 12:04 am
BK Thu Oct 14, 2021 12:04 am
p3taotoy wrote:I am able to export an orbx and this runs fine in the standalone
Using Maya 2022.1
Hi P3taotoy,
Thanks for the post.
Would you please let us know the scene contents or is it okay to share/PM a sample scene?
cheers
Kind Regards
bk3d
BK
Postby p3taotoy » Fri Oct 15, 2021 12:09 am
p3taotoy Fri Oct 15, 2021 12:09 am
It’s a plane with a diffuse shader and a daylight environment.
Thats it.
I’ll send a file if you need it but there is nothing else.
Peter
p3taotoy
Postby BK » Fri Oct 15, 2021 4:28 am
BK Fri Oct 15, 2021 4:28 am
p3taotoy wrote:It’s a plane with a diffuse shader and a daylight environment.
Thats it.
Peter
Hi Peter,
Thank you..
we just tested with Maya 2022.2 + 2021rc2-20.5 and still can not replicate the blue screen!
Maybe related to the CUDA driver or some file went corrupt!
Please reinstall the latest Nvidia studio driver and can also try running the command: "sfc /scannow" in Admin mode command prompt
cheers
Kind Regards
bk3d
BK
Postby p3taotoy » Mon Oct 18, 2021 3:43 pm
p3taotoy Mon Oct 18, 2021 3:43 pm
Quick.zip
(8.59 KiB) Downloaded 104 times
reinstalled a clean driver
472.12-desktop-win10-win11-64bit-international-dch-whql
ran as admin
sfc /scannow
Windows Resource Protection did not find any integrity violations
I should calrify "blue screen" this is in the ipr render window... not a blue screen windows crash.
So the scene file "plane, sphere, daylight env.
The hypershade renders a thumbnail so I believe the octane render engine is engaged and appropriately matched.
Plus the script editor says
// Octane: plugin is activated.
evalDeferred "shaderBallRendererMenuUpdate";
updateRenderOverride;
// Octane: engine started in 6 sec.
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/others/supportRenderers.mel line 67: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. To prevent this message from being displayed in the future, set the environment variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1 //
CreatePolygonPlane;
polyPlane -w 1 -h 1 -sx 10 -sy 10 -ax 0 1 0 -cuv 2 -ch 1;
// pPlane1 polyPlane1 //
scale -r 23.490372 23.490372 23.490372 ;
CreatePolygonSphere;
polySphere -r 1 -sx 20 -sy 20 -ax 0 1 0 -cuv 2 -ch 1;
// pSphere1 polySphere1 //
scale -r 2.56992 2.56992 2.56992 ;
move -r 0 3.858969 0 ;
select -tgl pPlane1 ;
// Octane: Material converter: Converting surface shader of shading group "initialParticleSE"...
connectAttr -f lambert1.outColor initialParticleSE.surfaceShader;
// Connected lambert1.outColor to initialParticleSE.surfaceShader. //
// Octane: Material converter: Shader "lambert1" (of type "lambert") is converted to Octane Universal material ("lambert1")
closeNodeEditorEd hyperShadePrimaryNodeEditor;
file -f -save -options "v=0;";
// C:/Users/peter/OneDrive/Desktop/Quick.mb //
So still not sure what might be causing it
Quick.zip
p3taotoy
Postby BK » Wed Oct 20, 2021 2:56 am
BK Wed Oct 20, 2021 2:56 am
p3taotoy wrote:
The attachment Quick.zip is no longer available
ran as admin
sfc /scannow
CreatePolygonPlane;
The attachment ScreenGrab.JPG is no longer available
Hi Peter,
Thank you for the sample.
We had no Octane errors! wondering if you are still using the 2021rc2-20.4 [BETA] viewtopic.php?f=109&t=78347
Would you please try reinstalling the OFM 2021rc2-20.5?
Cheers
Kind Regards
bk3d
BK
Postby p3taotoy » Wed Oct 20, 2021 10:59 pm
p3taotoy Wed Oct 20, 2021 10:59 pm
I am using the latest release.
If you have any other suggestions I'm happy to try them
Best
Peter
p3taotoy
Postby BK » Thu Oct 21, 2021 3:08 am
BK Thu Oct 21, 2021 3:08 am
p3taotoy wrote:Thanks
Best
Peter
Hey Peter,
thanks for the confirmation.
could you please try running Octane Standalone (viewtopic.php?f=33&t=78516)?
Then please run our latest stable OFM viewtopic.php?f=109&t=78238
We are working on implementing 2021 RC3 and hope to release it asap!!
Please let us know how it goes.
cheers
Kind Regards
bk3d
BK
Postby p3taotoy » Thu Oct 21, 2021 9:56 pm
p3taotoy Thu Oct 21, 2021 9:56 pm
Thanks for following up.
After a couple of reinstalls I am now rendering in maya with octane.
Thanks for your patience and help
Peter
p3taotoy
Next
Return to Releases
Wed Apr 24, 2024 2:34 am [ UTC ]
