Live DB Import keep network consistancy.
Posted: Mon Oct 15, 2018 8:08 am
Hi Guys,
I think it would be great when using Octane Live DB inside Houdini, to keep network consistancy beetween Octane Standalone network and Houdini Shading Network.
For exemple if i import a bamboo shader from live DB in standalone it give me this :
But when i import the same live DB shader in Houdini it give me this tentacular tree :
That would be great to get the exact same tree , and not have all the extra nodes.
Because it add complexity in the graph that is not needed, and it make the graph harder to read.
For the moment i had to
- manually delete each extra node
- set the correct value in the parameter view
That would be great if graph were identical by default
Cheers
E
Cheers
E
