Hair thickness not working?
Forums: Hair thickness not working?
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby sdanaher » Sat Aug 22, 2020 2:59 pm
sdanaher Sat Aug 22, 2020 2:59 pm
The thickness sliders seems to do nothing in the object Params. Hair is always super thin. H18, 2020.1.4
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher
Re: Hair thickness not working?
Postby juanjgon » Sat Aug 22, 2020 4:19 pm
juanjgon Sat Aug 22, 2020 4:19 pm
These parameters only work if the object doesn't have a "width" attribute. This attribute always overrides any other hair thickness parameter configured at the OBJ level.
juanjgon
Postby sdanaher » Sun Aug 23, 2020 1:25 pm
sdanaher Sun Aug 23, 2020 1:25 pm
juanjgon wrote:These parameters only work if the object doesn't have a "width" attribute. This attribute always overrides any other hair thickness parameter configured at the OBJ level.
OK, that makes sense. I see its created by the hairgen node where it can be changed or deleted, but its then modified by vellumsolver which always resets it to a tiny value. So you have to use attribute delete correct?
sdanaher
Postby juanjgon » Mon Aug 31, 2020 9:50 am
juanjgon Mon Aug 31, 2020 9:50 am
Yes, you need to delete this attribute using the attribute delete SOP.
juanjgon
Return to Bug Reports
Who is online
Wed Apr 24, 2024 6:23 am [ UTC ]
