Hi
I'm doing a smoke sim, importing the dop fields, converting to vdb for caching to disk, then converting back to volume for octane render. The result as you can see in the attached video is that the container jitters, probably due to changes in the bounding box. If I render the dop volumes directly it works fine but storage is then increased significantly. I've also attached the hip file.
the jitter appears only in the render, the viewport seems correct.
Yaniv
