Python: Octane node hangs
Forums: Python: Octane node hangs
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby sohara20 » Mon Feb 29, 2016 5:23 pm
sohara20 Mon Feb 29, 2016 5:23 pm
This python code is hanging houdini : hou.node('/shop').createNode( 'octane_vopnet' ). Works fine if the node is a mantra node. We are building a "uber" shader network with some promoted parameters to be more artists friendly and serve as a lookdev starting point. When we call this node in a python script (this script automates some image map connections) we get a frozen houdini.
Houdini 15.244
Octane 2.24.2
Shane
http://www.sohara.tv
https://vimeo.com/175783849-Octane Uber Shader. Coming soon
sohara20
Re: Python: Octane node hangs
Postby juanjgon » Mon Feb 29, 2016 5:33 pm
juanjgon Mon Feb 29, 2016 5:33 pm
I have not here the same version that you are using, but with H15.0.347 and the plugin 2.25.0.0 this python command seems to work fine.
Do you have this problem if you type the command in the python console in an empty scene, like in the attached image? I can install the Houdini and plugin versions that you have to try to reproduce it.
juanjgon
Postby sohara20 » Mon Feb 29, 2016 6:24 pm
sohara20 Mon Feb 29, 2016 6:24 pm
Ok we will give that version a go and see if thats a problem.
sohara20
Return to Bug Reports
Wed May 27, 2020 3:24 am [ UTC ]
