Embedded nodes visibility
Forums: Embedded nodes visibility
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby Stassius » Mon Feb 22, 2016 12:19 pm
Stassius Mon Feb 22, 2016 12:19 pm
On the obj level i can switch node visibility to make object renderable or not. This is logical.
But when i have an embedded multilevel obj-nodes (for example, RIG or fbx import) - Octane doesn't use visibility flag on the top level node. You have to go inside and manually switch nodes on-off, which is inconvenient in case of multiple nodes (such as fbx import).
To recreate this problem you can Create subnet from any node in the obj context.
Stassius
Re: Embedded nodes visibility
Postby juanjgon » Mon Feb 22, 2016 10:44 pm
juanjgon Mon Feb 22, 2016 10:44 pm
Thanks for reporting. I will try to fix this problem for the next build.
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
juanjgon
Postby Stassius » Wed Feb 24, 2016 7:49 pm
Stassius Wed Feb 24, 2016 7:49 pm
And another one. I noticed that bypass flag doesn't work in shader context. For example i use some Tool node after Texture and want to compare before-after.
Switching bypass flag doesn't work. I have to rewire network.
Stassius
Postby juanjgon » Thu Feb 25, 2016 11:13 am
juanjgon Thu Feb 25, 2016 11:13 am
Stassius wrote:On the obj level i can switch node visibility to make object renderable or not. This is logical.
This problem has been fixed in the next build.
juanjgon
Return to Bug Reports
Who is online
Wed May 27, 2020 3:47 am [ UTC ]
