Strange problem with text
Forums: Strange problem with text
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby Reynold » Wed Jan 13, 2016 3:08 am
Reynold Wed Jan 13, 2016 3:08 am
When I render extruded text I see some odd problems. See the images below for an example. When rendering in Mantra, the problem is not seen.
It is very easy (for me) to reproduce this error. Create a "Font" object, extrude, render. All settings are at their defaults.
Am I doing something wrong? or is this a bug.
Window 7 x64
Houdini 15.0.244.16
Octane 2.24.2.0
Let me know if you need more information
Octane Render Showing Problem
Mantra File Showing No Problem
Font Object
Reynold
Re: Strange problem with text
Postby juanjgon » Wed Jan 13, 2016 8:49 am
juanjgon Wed Jan 13, 2016 8:49 am
Currently Octane only can render simple convex polygons (mainly triangles and quads). You need to fix these complex polygons with holes adding a Divide SOP node, with the convex polygon option enabled, if you want to render them with Octane:
https://docs.otoy.com/Houdini/?page_id=711
Anyway I am going to add an automatic triangulation function in the Octane 3 plugin, so in the near future this step is not going to be needed.
juanjgon
Postby Reynold » Wed Jan 13, 2016 3:40 pm
Reynold Wed Jan 13, 2016 3:40 pm
OK, that makes sense. No problem adding the Divide SOP.
Thank you for your quick response.
Reynold
Postby Ebo » Mon Feb 25, 2019 7:39 am
Ebo Mon Feb 25, 2019 7:39 am
Hi, I am still getting that problem with a font sop. If it is possible can you please add it to the plugin? Thank you.
Ebo
Postby juanjgon » Mon Feb 25, 2019 1:25 pm
juanjgon Mon Feb 25, 2019 1:25 pm
Ebo wrote:Hi, I am still getting that problem with a font sop. If it is possible can you please add it to the plugin? Thank you.
You have the option to tessellate the ngons in the Octane spare parmeters, Tessellation tab. Once enabled the fonts should be rendered without problems.
juanjgon
Return to Bug Reports
Sat Apr 20, 2024 12:53 am [ UTC ]
