OctaneRender 2022.1 for Houdini beta build 2022.1.0.1 XB2
Forums: OctaneRender 2022.1 for Houdini beta build 2022.1.0.1 XB2
Re: OctaneRender 2022.1 for Houdini beta build 2022.1.0.1 XB2
Postby hyde44 » Mon Aug 08, 2022 5:47 pm
hyde44 Mon Aug 08, 2022 5:47 pm
Hi, its strange with this version , i've some problem to render in Photon tracing mode , the sampling get stuck before the end, so it didn't save and there's a weird different count of samples between the bottom stamp and the top counter ... :( I'm with houdini 19.0.589
hyde44
Postby juanjgon » Tue Aug 09, 2022 8:51 am
juanjgon Tue Aug 09, 2022 8:51 am
hyde44 wrote:Hi, its strange with this version , i've some problem to render in Photon tracing mode , the sampling get stuck before the end, so it didn't save and there's a weird different count of samples between the bottom stamp and the top counter ... :( I'm with houdini 19.0.589
This problem was a core issue that will be fixed in the upcoming 2022.1 XB3 plugin builds.
juanjgon
Postby juanjgon » Tue Aug 09, 2022 8:57 am
juanjgon Tue Aug 09, 2022 8:57 am
luminouspowerhouse wrote:Juanjo, changing any parameters under IMAGER (in Octane RenderTarget), like ocioView, adding LUT, etc - doesn't do any changes in IPR, even with full scene reload.
does yours work as expected?
Here everything seems to work as expected, at least with the upcoming XB3 core libs. Can you please check this problem again once we release the new 2022.1 XB3 plugin builds (that should be available around next week)?
juanjgon
Postby hyde44 » Thu Aug 11, 2022 1:32 pm
hyde44 Thu Aug 11, 2022 1:32 pm
Great ! Oh and Caustics are incredibly slow when using hdri instead of Octane sky will that be fixed too in xb3 ?
hyde44
Postby shishkovdima » Fri Aug 19, 2022 9:25 pm
shishkovdima Fri Aug 19, 2022 9:25 pm
Houdini 19.5.303, Octane Light doesn't seem to work. Some textures are missing. This is just the default settings with increased intensity.
Is anyone else getting the same issue?
shishkovdima
Postby juanjgon » Sat Aug 20, 2022 11:29 am
juanjgon Sat Aug 20, 2022 11:29 am
shishkovdima wrote:Houdini 19.5.303, Octane Light doesn't seem to work. Some textures are missing. This is just the default settings with increased intensity.
Do you still have the same problem with the just released 2022.1.0.2 XB3 build?
juanjgon
Postby shishkovdima » Sat Aug 20, 2022 9:17 pm
shishkovdima Sat Aug 20, 2022 9:17 pm
2022.1.0.2 XB3 build works great so far. No errors. Thank you very much.
shishkovdima
Previous
Return to Releases
Wed Apr 24, 2024 10:26 pm [ UTC ]
