Comign from Redshift - Ramp Node Equivalent?
Posted: Mon Nov 27, 2023 4:34 pm
Hi is there a simple way to run a texture through ramp like in Redshift? Looking for a way to quickly remap colors/levels. Thanks
Community Forums for OTOY Customers
https://render.otoy.com/forum/
vurt wrote:Hi,
it's called "gradient" in Octane, at least in Houdini plugin. Need to get used to the name yeah, I still sometimes search for ramp and can't find it
RyanJP wrote:vurt wrote:Hi,
Thanks.. it still doesn't really behave the way I'd expect. Seems like the image adjust node is the way to go for simple levels manipulation, just seems like overkill and also the node is awkwardly large. Ah well, most everything else is better in Octane
ricky_otoy wrote:The gradient node has been fixed, it should behave in a way you are probably much more accustomed to - should in the next update.
