PDG batch render network slaves not available
Forums: PDG batch render network slaves not available
Houdini Integrated Plugin
Re: PDG batch render network slaves not available
Postby Barry Convex » Tue Feb 16, 2021 12:30 pm
Barry Convex Tue Feb 16, 2021 12:30 pm
I updated Houdini and after several attempts, it finally worked ! Honestly, I'm not sure Houdini's version was the issue and I'm pretty certain I had released all slaves before rendering...
Anyway, thanks a lot for your time !!
Win7 64 - Linux Mint 16 | Gigabyte Gtx760 4gb | Intel i7 3930k | 24gb Ram
Barry Convex
Postby jiayujinn » Wed Oct 27, 2021 7:59 am
jiayujinn Wed Oct 27, 2021 7:59 am
Hi, I am running the same issue, tried Octane_disableNetworkRendering didn't work.
I am using a rental version of octane, so it won't let me dive in the network option.
Is there any other solution?
Octane 2020.2.3.0 / Houdini 18.5.532
jiayujinn
Postby juanjgon » Wed Oct 27, 2021 9:13 am
juanjgon Wed Oct 27, 2021 9:13 am
Sorry, only to be sure. What's exactly your problem?
juanjgon
Postby jiayujinn » Wed Oct 27, 2021 1:02 pm
jiayujinn Wed Oct 27, 2021 1:02 pm
Thank you for reply, Juanjgon.
I am trying to render multiple settings out of my scene using PDG, each setting have only 1 frame.
I tried to speed up the processing time by increasing Slots Per Works Item to make it run multiple renders at the same time.
But it will show up an Authentication window says 'Another instance is currently performing authentication tasks'.
I tried disable network rendering using Textport. Didn't work.
And I can't turn off network rendering from ROP because I am using a rental license.
I am using Octane 2020.3.0 and Houdini 18.5.532
How do I prevent this message coming out?
Thank you very much!
jiayujinn
Postby jiayujinn » Wed Oct 27, 2021 1:39 pm
jiayujinn Wed Oct 27, 2021 1:39 pm
Looks like I can just ignore the Authentication message, the render will still proceed.
jiayujinn
Postby juanjgon » Wed Oct 27, 2021 2:54 pm
juanjgon Wed Oct 27, 2021 2:54 pm
There are some fixes related to the licensing authentication from multiple sessions in the latest 2020.2.5.0 build. Perhaps you could check if this problem is fixed in this build.
juanjgon
Previous
Return to Houdini
Users browsing this forum: No registered users and 13 guests
Sat Apr 20, 2024 12:07 am [ UTC ]
